nailsandrails
Ok guys, I had the sled apart doing some different things. I had the suspension out and had the rear end jacked up high in the air. About a week later I notice some oil on the garage floor. After much searching for the leak I found that it was coming from one of the fuel lines.I pulled the carbs and the fuel line closest to the gearbox was full of oil. I actually pulled it off the pump and pure oil came out of the pump. It has to be because I had the back of the sled in the air, but I have never had the fuel pump apart to see how it is set up. Has anyone else ever had this happen, or does it make sense that it could happen. I'm assuming now that I have it level again it won't seep any more oil, but I'd like to know for sure. Thanks guys!
