TimeBomb
i ordered sportech handguards for my viper. do they hit the stock windshield while turning sharp?
rtx meirda
Yep! It does
TimeBomb said:i ordered sportech handguards for my viper. do they hit the stock windshield while turning sharp?
I believe that with the stock handlebars that they will hit. Here's a couple of pics of the set up I've got on my Vipe. I've got a 5" riser with Firecat bars, using Power Madd hand guards with Rox mounts. With the low windshield there's enough clearance at full lock without touching anything.
rtx meirda
You can chop your windshield down.
YamahaXtreme
They will hit with stock windshield and stockbars, get a 2" riser and you'll be fine.
Steven DeMarco
- Feb 16, 2004
I put the sport tech guards on my viper without a bar riser and
they hit the windshield.
i trimmed the aluminum mounting brackets back almost 2 inches
re-drilled and tapped the mounting holes and remounted them.
they work great and dont hit the windshield.
also they are closer to my hands and provide better wind blocking.
be careful not to trim off too much or you will hit the brake lever
rtx meirda
Great idea!!!
redsnake3
when i put mine on with the 3" risers they still just touched the windshield.
auji700triple
Wast that windshield cut down any Joe?
redsnake3
no that was the stock windshield. its far away from my cut windshield.
TimeBomb
forgot to mention i have a 2" riser
I have a 2" riser with the bars tilted all the way to the top and forward. I can't see it hiting with a low windshield. I need to order the shield and guards soon. Who has the best price?
quebec#1
Will they hit if i have a 10 inch low chromy ?
sx600
- Aug 10, 2004
I have the powermadd ones with a low windshield and a 1" riser block - they do not hit at all.
richierich
nb.what style windshield and guards you want? i have some powermadd ones with mount for $45.
B2SO
- Aug 18, 2003
I have power madd handguards , and a stock windshield with a 2' bar riser and if you mount the guards in the very first hole so your hands kind of just slip in between the gaurd and the bar they just barley touch when you turn the bars all the way one way or the other , worked great for me last year .. i will post some pics tonight ,
Cuzino19
I have a low blue chrome windshield with 3 " rox risers and they dont come close to touching.
quebec#1
So is it a must to install risers ?
