sx600
- Aug 10, 2004
If I put in a 53/43 helix and green spring in my viper, will this hurt gas mileage at all?
I am wondering the same thing. I have one that I just need to install. I guess it will provide more of a bottom end pull. I really can't see it burning more gas..
sx600
- Aug 10, 2004
I haven't bought the helix yet, I'm kind of waiting until I hear about the MPG. I bought the spring last night though. I was told my rich motor sports and bender at the haydays that the spring alone would wake up the viper some -- thus I might just go with the spring for now.
yamaholic22
no the helix won't hurt your gas mileage, if anything it should make it a tad better in the lower and middle throttle positions because the higher initial angle will put the sled in a lower "gear" ratio, and it will rev less at these throttle positions compared to stock.
Who would you recomend you get the Helix from? Is there a better mfgr. than others?
sx600
- Aug 10, 2004
I will either be getting a hauck, pioneer, or bender - I'm sure they are all about the same quality. I've had a hauck helix in a vmax sx that I was very happy with.
I guess if you can keep your thumb off the throttle, it should get the same or better MPG - but with the extra power, that will most likely be hard to do.
*99sRx700*
a good honest reliable source would be from allen right here on the forums. His name on here is SRXSPEC. Send him a PM or go to www.ulmerracing.com and tell him what yoru looking for, he can help you out at a very reasonable price. I would go to him with all my clutching needs, very knowledgable, experienced guy, treate dme right, and Im sure he will treat everyone else right also!!!!
I need to be able to beat my buddies 1994 ZR700. I am also thinking about getting CarbonTech reeds..
yamvip
Get the helix from dalton.
I bought mine used from Maxdlx. I think its a Dalton. No way to be sure.
quebec#1
Will we loose top end speed ? With a 53/43 helix and green secondary spring ? Im going to try this set up as well.
Im also installing 121 studs up the middle.
sx600
- Aug 10, 2004
I'm trying to decide which helix would be best for a stock viper as well. I've also been told the 52/44 would be a good choice to maintain almost stock like backshifting.
I don't believe much will be lost on the top, but hopefully somebody else will help us with that...
03viperguy
lol, I am considering the same setup! everyone with a viper must have just read the tech sections in the last few weeks
quebec#1
Id rather go for the helix and spring change than heel clickers, ive heard some good thing about them but alot of bad things , such as needing lots of time to fine tune them .
quebec#1: You heard bad things about???? The 53/43 or heavy hitters?
quebec#1
heavy hitters !
