Do the plug wires screw out of the coil like they do out of the sparkplug caps? they look like they have some type of glue in them or somthing on the coil side.
Brad
- May 23, 2003
they are glued in. I have replaced them on a exciter before, had to dig the wire and glue out of the coil and glued a new wire in
Phazercory499
Yeah i have the same problem, I bought some NGK wires for my '90 phazer but couldn't get the old wires out, Still haven't got them out yet. any advise on how to do it?
sxviper32
i'm in the same boat as you guys, can't get all that crud out of there. is there a stud sticking up in there? any help!!! thanks!!!
Phazercory499
Wires.......
The guy who i bought mine from said " they should TWIST right out " that was BS.
sxviper32 said:is there a stud sticking up in there? any help!!! thanks!!!
I dont want to try and rip em out if there is no stud to push new ones back in on to
Mac
Foul family pictures
Come on Hoff. Family pics like that should be prohibited!!!
Hoff is that you?
Hoff is that you?
sxviper32
nobody has replaced their plug wires??? please help us!!!
I replaced my wires on my 1993 Exciter SX. It had the sealed coils as well. I ran NGK wires. What I did was clipped the wires about 3 inches from the coil. There is an adapter that Denis Kurk sells that you will need. It's about 5 or 6 bucks and you just twist one end on to the coil side and the other to the NGK wires. This sounds flimsy, but it worked and worked well for my sled.
Denis kurk part# 20-0355 you will need one per coil
