Exciterfan
I'm about to upgrade the track on my2001 SXR600 and I have a question relating to just how much I have to take a part to get the Drive shaft out. My Clymer manual seems to indicate that I can leave the chain case installed (less the gears and chain) and once I remove the PTO side drive shaft bearing I shpould be able to "remove the drive shaft". In my previous experience with my old Exciter, I had to remove the entire chain case and slide some of the drive wheels to the right just to be able to slide the shaft far enough to get it out. Also do you recommend that I change all of the bearing s while I have it a part? I was thinking of changing both of the bearings on the PTO side (Jack shaft & drive shaft) since they are not bathed in oil inside the chain case. If I don't have to remove thew chain case then I think I'll leave those bearings alone.
Anyone have specific experiencxe with an SXR? All advice is greatly appreciated. I want to minimize the time I spend on the garage floor wrestling with the machine.
Thanks in advance.
Exciterfan
Thanks in advance.
Exciterfan
