How large belt on 1994 V-Max 4 750
kimoaj
Norway
Hi everyone!.
I`m going to help a friend change his belt (you call it "track" ?) and he is wondering how large "cams" he can get?.
My dealer has the following sizes: 32mm, 38mm, 51mm and 57mm.
Does anyone know ?:).
Thanks fellow norwegian ;) . Ka du sei tell godt Gjendor?.
What if you go down a few sizes on the "sprockets" ?. Wount a belt with larger lugs fit then ?.
Gjendor? is that the same as Glunt? or something like t hat?
I guess it will fit if you go down on the sprockets/drivers. Might as well get anti-ratchet ones. Is that a 307 or 345 cm long track? 307 by 51 mm is faar out man.
:) Don`t you speak norwegian norwegian?.
The belt is 307cm . A friend of me has 51 on his Exciter I think, could work on a V-Max 4 also then ?
My guess is that I live 200 km from you :)
Yes, as Osko Sarre in Karigasniemi says
"we speak, english, norsk and sami"
51 mm could work on a v-max 4 but will reduce top speed due to wind drag in tunnel, and heat up and lose lugs if you ride real fast across a lake. I'm sure it would be great in powder though (the track), but then you got the wrong sled to go "powding" with from the beginning!
Do not hesitate to "PM" me, that is send me a "private message" if you want to talk in norwegian.
