auji700triple
hey guys, i mite be getting some Race gas (c-12) off someguy and he used about 5 Gallans of it.. can it go bad?? like regular pump gas??.. thanks -aj-
Yes it can go bad. You must keep it in a place that stays a constant temp and put it up off the floor with some pieces of wood about 2" off the ground. Also make sure you close it good. The best way to keep it good is to pressurize the tank, let me see if I can find the info on how to do that.
auji700triple
Alright thanks, im going to be checkin up on this gas anywyas i dont want to buy it if its shit to run! Pump gas is probably better to run than spoiled race gas
n2oiroc
as long as it stays in the steel drum out of sunlight it keeps for a while.
