SX700R clutching
slim
ontario
2001 with end dumps 51/43 helix.I see in tech pages i should be running a 47/41 helix with 89L weights,14.5 rollers. I know where to get the helix from but are the weights and rollers dealer items and would heel clickers work better. I have added lead to my stock clutch, works alright but always trying to get a little more low buck performance.
The rollers & weights are Yammie items. Run a 51/43 with a 2.4 gram rivet & helix wrapped at 60-70 degrees. You gotta have those rollers for sure.
Are my rollers 8mil or 9mil and is the 2.4 gram rivet for the 89L weights.Thanks in advance.
Rollers are 9mm. You need part # 8cr-17624-00-00. The rivet is for the 89L weight. For lighter rider you might need a 3.1 or 3.6 gram rivet.Get a w-s-w primary spring too.
