What is a leak down test?
I assume a more comprehensive compression test.
tagoes10s
I can run a leakdown. What is the acceptable range for a hot motor? Never done a leakdown on a 2 stroke, just heat the motor up good and pull the piston to TDC and test?
Mrviper700 shoot me a PM with a cost to work your magic on the ports/piston mod.
Sledboy Leakdown here is a quick little description of a leakdown test.
