Risers
yammy_freak03
Winnipeg,Manitoba
Website
www.winnipegsportandleisure.com
K i went to the yamaha dealer today and order set of bars and a riser block. The block is 4". My sled is a 98 srx so i believe the cables are already going through the air box. Now if i put cables from a 01 srx on, which i believe are longer then the 98's would i still have to extend some cables?
yes you will have to order mountain max cables. Thats what I had to do on my viper and it had 3 " risers.
if your going higher than 2" you might want to get an articulated riser. that way you can move the bars forward and not just push you back farther.
