Ace6222
Hey everybody,
Now that the temperature is dropping, and there has been some snow flurries, it is time to get some pipes for my Viper. I want a powerful reliable set, and I really want to turn some heads. What should I get, and is anybody selling theirs? Thanks in advance.
Ace
Ace
SLP are the best power with quiet clean sound...next would be CPRs, but SLP have better fit and finish.
03viperguy
not sure you will find a REALIBLE set for the viper, unless you are the tinkering type and love rejetting those flatsides........
The SLPs are a great set to bolt on, read instructions and go....
03viperguy
slp's dont give that same burn down tendancy? just when people try to get better mileage the sleds let go?
auji700triple
I hear CPR Pipes Give you the most HP but for realbility, no pipes will help you with that.
*99sRx700*
i cant say i agree with tha either. There are plenty of people that run pipes reliably. Just jet in teh safe range, abit rich and you should be fine. Pipes in my opinion dont hurt reliablity when setup right
03viperguy
just with the lean burning cdi I hear a lot of horror stories
*99sRx700*
i believe that is only around 8700 rpm, if someone else can verify that. I belive if you keep it above that, you will be just fine
Ace6222
What brand would make me the loudest? Thanks
auji700triple
hmm..... cpr's i think.. Just watch out for the timing Spike in the viper. Like *99sRx700* said, around 8,700 will burn you down so stay above that!
vipertripplexxx
aaens are the loudest, jaws are the lacking in power. The rest are a wash.
I personally like the SLP pipes, just my opinion though!
It doesn't matter which pipes you put on, do the setup right the first time! I recommend the opti-cool head gasket, SRX base gasket, and rear heat exchanger to be installed on any set of pipes going on a Viper! After you install all that bleed the coolant system properly several times until you have all the air out and then bleed it once more just to make sure! Also run a heat range 10 spark plug will help make things live longer as well and avoid detonation!
TopGunnSrx
So if you jet a little on the rich side and stay away from the spike you "should" be safe with pipes?
03viperguy
yes. if you want to pull it and go, pipes are NOT a good idea
ak ryda
I run SLP's on my viper. Two years without touching the jets after the initial set up. I have run from negative 10 to 40 above and from sea level to 6000' without a problem and has more than enough power to handle any stock 800. On snowest it is a landslide that SLP pipes give the most consistant HP/quiestiest sound/most reliable/ with the best fit and finish. Also with all the research I have seen on snowest and on here I have not seen a single burn down from someone running SLP pipes. I wouldnt waste your time with a can when that $225 is almost 1/3 of what pipes cost and you will get much more satisfaction from turning your sled from 600cc class power to 800cc power class.
03viperguy
wow, didnt realize slp's were that reliable! I never mess with stuff like that because I am not enough of a tuner. and I can ride from -20 to -25 up to 45-50 in the spring. just doesnt seem like I could possibly jet for that range and not sacrifice reliability or have it run terrible once warm.
performancexplorer
Viper SLP ceramic coated tripple pipes for sale
I have a set of SLP ceramic coated tripple pipes for sale for $600 ($1,150 new) including installation instructions. They were on a 2002 Viper that I have since sold. They are in excellent condition and have approximately 1,000 failure free miles on them. Huge increase in power. I also have jetting, and Maxximum Performance or Reichards Performance clutching for sale to optimize performance. I used Digitron exhaust temperature/tach gauges to dial in jetting and clutching. Also have V-force reeds that were used in the performance package.
