eracer
- Feb 3, 2004
First time posting new to board I launched my sliders and don't know the length that they should be cut to the dealer said to cut them to 121" however I think he was thinking of the track length Royal says 52 1/2, that's the length of the ones I bought and they are too long. Called Yamaha Motors Canada and they don't know either they said cut to the length of the old ones I know 36 and 29 are not the right lengths to cut them to.
And what's the best way to get the broken screws out of the suspension frame broke off clean with the surface.
Any help is greatly appeciated
Eracer.
Eracer.
121" uses a 42-3/8" hyfax.
136" uses a 49-7/8" hyfax.
Oultman
I think what your dealer meant was to get the 121" When you get the slides you'll see the package says 121" even though thats not the actual length, I assume its done to eliminate confusion, haha. Even if you go the longer ones they are real simple to cut, measure off the old ones and cut them, I use a band saw sometimes.
eracer
- Feb 3, 2004
Oultman said:I think what your dealer meant was to get the 121" When you get the slides you'll see the package says 121" even though thats not the actual length, I assume its done to eliminate confusion, haha. Even if you go the longer ones they are real simple to cut, measure off the old ones and cut them, I use a band saw sometimes.
Thanks however I can't use the old ones as they got chewed up by the track I think edunn69 has the info I need.
Thanks for the help
eracer
