Cuzino19
Ok i bought a different windshield and how does the fairing piece in between the headlights come off? Do i just pop it off with my fingers or is there a special way to take it off? What is the best spray paint to use on this piece because I want to paint it either black or white.
The triangle fairing? I just installed ALL new fairing yesterday and a new windshield. The triangle peice has tabs on it that are installed in the side fairings. I installed mine by juse bending the triangle peice to fit so just carefully pull out each side, then tilt the fairing forward a LONg ways and that will allow it come out. There is a "L" hook at the bottom center between the headlights that keeps that from moving.
Summy pry out sides, tile whole peice forward about 120 degrees and she comes right out. DO not pry on the lower center part the side must come first.
auji700triple
I used a Fusion White For mine, works and looks Awsome! I Used that paint to paint everythign you see in my avatar..
yam0498
i have a set of black trim and looking for blue. are yours blue? pm me if they are. thanks
