ModMMax
I need to build a T fitting to supply fuel to the jets added from the nitrous kit. I have purchased a brass T fitting as well as 3 brass barbed fittings that will thread into the T. Should I use teflon tape on the brass threads? If not teflon, is there a thread lubricant/sealant that should be used for gas?
n2oiroc
dont use teflon tape! use a paste thread sealer in the plumbing dept.
