The sled is a 91 exciter .40 over.
I pulled off the head.
The first thing I noticed one side had a small amount of carbon covering the pistion the PTO side had much less. You could still see the original gray color.
Then I noticed the edge of the pistion near the exhaust port looked like it had crumbled away. I assume it melted.
The cylinders were not bad. just a few scratches on each.
The sled was only on the second tank of gas after an engine rebuild. It was running great until it was shut off.
Can anyone tell me
1) Why one side had more carbon? I believe both were firing.
2) what would cause it to melt?
TO give a little history on the sled:
A friend bought it with a blown motor. Had the cylinders bored and installed wiseco pistons. Well the cylinders were nikasil so it seized in about 3 miles.
It was given to me in the fall. I changed the seals, cylinders, pistons and gaskets. It was the third time out probably only about 60 miles on it. THe cylinders are from an earlier exciter (no nikasil).
Can anyone tell me
