power inc end dump setup <turk>
sxrsist
sask. canada
i remember you had a good knowledge of setup, bought 2 sets at haydays amd know have to install, both on mm, one is going on reeds lightweight 00 mm, need jetting specs and recomended clutching and rpm goal,1 is a 98 mm with a cut down 2 inch the other is a 144 2 inch 00 mm, thanks
147.5 mains, #50 pilots, raise needles 1/2 ;89L weights with 2.4 gram rivet; 51/43 helix with green at 70 degree wrap. Run em at 8300-8600 rpm. Nice pipes & make great power.With a geared down MM you might need more weight in the primary. Stock 8cr,s won,t work...too light unless you run a monster helix.
