How many guys would be interested?
Srxspec
Your #1 performance shop!
Menno, SD
Website
www.ulmerracing.com
Guys I have a few people with stock Viper's or SRX's that are interested in clutching with Super Tips. I have access to both a SRX and a Viper that I could use for test mules to come up with some different clutching packages. How many would be interested if I did this?
So the question is, would you be interested in a clutch kit using Super Tips for your SRX or Viper?
Kits would probably cost in the range of $225 for the cheapest (just weights) and $425 for the most expensive (weights, primary spring, secondary spring, rollers, and helix).
So if we are running an er secondary, we only need the weights, and maybe primary spring? I'd be in. Maxdlx
ya thats the only prob with running that er, me and you have to guuess at the clutching and play at it duane is helpfull buy you have to do all the testing, i think they are a great system once you get them dialed.on a stock sled i was running i got it workin great, but on a cppr piped viper i couldnt get it to pull like jeffs cpr hh kit with the stock 47. you could tell backshift was way better but didnt pull close to the same. and i had 4 helixes from 48-52 degrees,just need more time i guess
what are super tips, never heard of them? whats the benefits of this clutch kits? any other info would be greatly appreciated, thanks!!!
im in , but i need more help getting me setup for the 136 bender piped 02 viper with a team secondary ....
The Super Tips have 6 places (3 spots per side) on each weight that are adjustable with washers. You can add up to 42 grams per weight as well. The gains are going to be low end and mid range with good top end and backshift yet as well. The weights are a great all around trail weight. I don't have a picture of the new design but will this weekend!
I know some of you were interested in seeing what these weights look like.
Maim, I do have a 40 gram base weight as well.
Guy's these weight's work awesome.The et quicker and have more mph than heavy hitter's.Iv'e been testing them on asphalt.It's a top notch weight.Allen has some great set up's too.
why would the top end on these be any better than the heavy hitters? Profile looks strikingly similar to the heavy hitters, and you could throw a lot in the tips.
cool ill try to call you but i work permanent afternoons (3:30pm-12:00am). it might be easyer to email me at maim1974@hotmail.com till i get a chance to call you. adress it to cameron so i dont delete it as junk mail.
thanks\
cameron
