SRX Exchanger on a Viper
NLViper82
Marystown, NL
I just went to put a srx exchanger on my viper and i seen the bleed hole is different. Do you just drill a new hole for the bleed screw or do you drill and tap another. Or does it make a differnence. Thanks.
Drill a new access hole in the tunnel. This was the case with the ones offered by Yamaha as they are actually the same part.
If you need the measurements I can find it for you, or you can just mark it yourself.
