vmax6
Anyone using one these? Any problems or concerns. How much does each flat on the cam change the F.R.A. location? 1/32" 1/16"????
Or is the Fast Jack a better option.
grapeape
I have a question... After owning M-10's for 7 or 8 yrs, I set my FRA and never moved it, why spend money to adjust it?
vmax6
Grapeape
Only had my M-10 for a year but trail conditions or adding a saddle bag on the back require a change to keep it in the sweet spot. I tend to like a soft suspension so late in the day trails or lack of groomed trails require a change. Thats why I am concerned how much each cam location moves the FRA
grapeape
IC what you are getting at, each FRA change is good for about 25lbs of rider weight, so you would go 1-2 marks to get from stiff to soft. I always ran Ohlins as well, and adjusting the comp on the resivoir accomplished the same thing.
vmax6
Thanks Grapeape I also have the adjustable Ohlins and your right thats is an easy way to get small adjustments as conditions change. Still trying to justify the cam-it for quick changes when my wife wants to change sleds.
Is every notch on the Cam-it approx. 25lb adjustment also?
yamaholic22
actually adjusting the clickers on the ohlins makes a real big difference in my opinion, probably set everything else medium and do the hard/soft thing with the clickers.
grapeape
6 I spent a fair amount of time getting my sled set up, so the harder I ride it, the better I like the M-10. I had rider weights from 160 up to my 280 and no one ever complained about the ride quality. Could it be that they did not know what they were truly missing? For your wife, a small part that would adjust the skid to perfect for her would be priceless, as when she is happy, you are too.
