W-Arm broke!
SRXdude
Bismarck, ND
Damnit! W-Arm broke on a trip up north yesterday. Caused us to come home early. I just had the suspension out for re-bushing and inspected the W-Arm for cracks. Piece of shit (w-arm that is!).
Anyway, I have 4k on my sled. Should I put another stock Yamaha arm on it or get a aftermarket like Maxximum Performance?
Thanks!
just get your old arm welded up by a machine shop and add gussets between square tubing got my done this way never break again cost me 28.00 dollars
Could you post some pics of this? I would like to see where it broke, I use to have this problem with the old Enticers, they would brake also, I welded them up and reinforced them, no more breaking, but I wondered if the aftermarket one was stronger and lighter, may be a good excuse to upgrade to one, lighter and stronger is better IMHO..
w-arm pictures
Guys
I finally got around to cleaning some shit out of my garage and took a picture of this.
This is the way it came out of the sled. Totally broken. The only thing holding front of the rear suspension in was the shock. I had to ride it about 40 miles back to the truck once I found out the arm was cracked. I suspect it broke the rest of the way from the stress of having one side cracked.
i gotta do mine on my Srx but mine isnt that bad just cracked one square tubing apart from the other a simple weld her up will fix it and ill put in some gussets
WHOA You really broke it!
Are the 2003 W-Arm's any different in the vipers? I hope mine doesn't break in the near future, since I'm getting close to the magic 4k mark. Ahhhhh!
If you really ride hard,i would get the w arm from maximum performance.I rode my 01 hard and broke the w arm 3 times.I had it welded,gusseted with chromoly plates,and it still broke,my friend all have rev's and zr's s,so when the trail gets rough my sled takes a beating just to keep up.
