setup sxr700
sledfreak700
White Lake, MI
just bought bender triple pipes for a 2001 sxr.any info on jet sizes,and or best clutch setup.any info gratley appreciated. :yam:
150 mains will be good down to probably something like -20f. For clutching, many different weights work well, such as the 8DN-20 and 89L, the 8DF's also aren't too bad, a little less aggressive though. What are you looking for out of your setup? Want to rev those babies around 8700-8800 to get on the peak power of the setup. Anything else done to the engine? If you haven't done the reed notch or reed spacers, that is a very worthwhile improvement for quicker throttle response and a cleaner low end and midrange.
52.5 pilots, 150 mains, needles raised 1/2 right across, 14.5mm rollers, g-p-g primary spring, 89L weights with a 2.4 gram rivet, 51/43 helix with green secondary spring at 60-70 degree wrap. This is officialy post # 1,145,139 on a Bender piped 700!!!!!!
