i have a 99 sx 700 that on the last ride of last year all of a sudden started blowing belts and previous to that when i put new belts on the would squeal for a while any help would be great
if its squelling its probaly ur center to center from primary to secondarys off mine use to do it all the time but i think i remebr there was somthing else that finaly made it stop i think it was takin out like this plastic washer in the seconday or adding it i didnt do it i had the guy from the dealer ship do it but i think it was takein out a shim or adding one.
check you clutch alignment centre to centre and offset.
For belt squeel you remove a washer from each of the three bolts behind the secondary. This will drop the belt slightly deeper in the secondary.
