Camoplast track direction
hoffam19
The UP
there are arrows on the track, Im assuming the arrow on the top of the track should be moving toward the front of the sled, the same way it is pointing, correct? Im just wondering because if this is so the camoplast stamp would be upside-down when looking at it from the back. I dont know if this matters and i could care less if it is, but it just made me wonder if i was putting it on the right way.
you got it.arrow points in the direction of track rotation.and the como stamp will be upside down.
now, what about V shaped stud patterns-- should the point of the V be pointing in the same direction as the arrow on the track (towards the front)? or does it matter?---cause mine is NOT
About the V stud pattern i don't think it makes any difference
yeah but it looks better, cooler if u will, when the arrows (stud patteren) is pointing the same way as the track rotats
