there are arrows on the track, Im assuming the arrow on the top of the track should be moving toward the front of the sled, the same way it is pointing, correct? Im just wondering because if this is so the camoplast stamp would be upside-down when looking at it from the back. I dont know if this matters and i could care less if it is, but it just made me wonder if i was putting it on the right way.
Brad
- May 23, 2003
you got it.arrow points in the direction of track rotation.and the como stamp will be upside down.
Millinocket Rocket
now, what about V shaped stud patterns-- should the point of the V be pointing in the same direction as the arrow on the track (towards the front)? or does it matter?---cause mine is NOT
thanx for the info, track is on. everything went very smooth.
Brad
- May 23, 2003
About the V stud pattern i don't think it makes any difference
Millinocket Rocket
thanks brad-- i wouldn't think it would matter-- scratch lines are scratch lines right?
yeah but it looks better, cooler if u will, when the arrows (stud patteren) is pointing the same way as the track rotats
