Tod
going through the rear suspention. Need to get the smallest wheels off, (the middle shaft wheels) do i need to use the press just like I do when changing out the two inside idler wheels or will these just pop off??
I remover the c-clip and tried to pound them off but they are not moving.
Use the press that I do not have or beat them????
Thanks,
Tod
Thanks,
Tod
dganey
wheel removal
Just finished mine. I had to pound them off--a lot of force. I just used a hammer because I was replacing the wheels. To install the new wheels, I used a large socket to slide over the shaft to seat the wheel. I then slide it through the frame, had a friend hold a piece of wood against the opposite side of the shaft and seated the other wheel.
Hope this is helpful.
Dusty
Dusty
