yamvip
I'd clean them up a little better than that.But then again I tend to be a little anal.
Millinocket Rocket
hey- i thought those were supposed to be self cleaning! lol
NA...........I GUESS I'M ANAL 2
I took mine right off, soaked them in Solvent 4 about 2 beers
, Then sprayed Brake cleaner on them. Then to get the last little bit off warm soapy water and 1000 grit wet paper, and gently wet sanded them ................they come out like brand new. Of course you might not want to pamper your Favorite Yamaha like I do.
My Wife gets Very Jealous, of the way I treat all my YAMAHA's........Drives her nuts
Cleaning off the crud off my buddies pipes was way harder.
SO MUCH 4 SELF CLEANING
, Then sprayed Brake cleaner on them. Then to get the last little bit off warm soapy water and 1000 grit wet paper, and gently wet sanded them ................they come out like brand new. Of course you might not want to pamper your Favorite Yamaha like I do.My Wife gets Very Jealous, of the way I treat all my YAMAHA's........Drives her nuts
Now that I think of it.
Question...........SELF CLEANING Power Valves
Answer............U Clean Them Yourself
How do they come off? Thanks
bucky
I just get the big gunk off and clan them til they are smooth. That is all that really matters.
yamvip
I clean them so they look jus tlike new!
Millinocket Rocket
BOUNTYHUNTER said:Now that I think of it.
Answer............U Clean Them Yourself![]()
Ohhhh--- is that what that means! lol
blueblooded
I scrape the thick junk off with a razor blade and the i spray them real good with carb cleaner and scrub them with a scotch brite pad,they come out like new.
tbalz
I clean 'em the same way as Blueblooded except i use brake cleaner instead of carb cleaner.
I also make sure that all the crud is off of them and scrub with scotch brite pad and break clean… just don’t loose your pencil eraser in the motor like I did….
On a side note, do you guys normally replace the gaskets each time you clean the power valves or are the reusable the first few times? I'm about to clean mine for the 1st time.
yamvip
hmmmm.......I never thought of that I've been reusing mine.I guess if you notice a leak,then replace.
yamaholic22
Yea i always reuse them until they leak. Only had a leak once
