purchase a stiffer front skid spring the stock one is to weak, i went to a 2.8 and i weigh 190 and feel i could have went with a 3.0 rate instead, big difference than stock and much better ride....also loosen up the preload on your rear shock and keep your control rod gap toward the tighter side for coupling not transfer....CP
Mjet67
Maybe, I'll have to get a stiffer spring....Got the preload set all the way on the rear spring....still no gap on top when sitting on sled...
vmax600
FRA??? Could someone tell me what FRA stands for? Thanks
sandmanmike1
Mjet67 said:OK I've got the center spring up almost all of the way.....the FRA in the center position....how do I adjust to get the transfer rod gap at 50/50??
When I sit on the sled there is no gap on top..........?????![]()
I beleive that is done with pre-load or spring setting on rear spring.
Mjet67
vmax600 said:FRA??? Could someone tell me what FRA stands for? Thanks
Full Rate Adjuster.....Bracket on front end of rear shock....To adjust the stiffness of the rear shock.
vmax600
Thanks Mjet.
As soon as I can get time to adjust mine I will. Thanks for the input guys. I don't think it's going out riding anytime soon unfortunately so I got some time to fix it.
