grizer
- Sep 18, 2005
So I put my new track on and putting the rest of the sled back together.
I started to put my chaincase back together last night and I have found that my bottom gear doesn't seem to go all the way onto the shaft. I only found 1 post about it on here it says it is common for a few mm gap. Mine looks like its not on all the way by 1/4 - 1/3 of the gear thickness.. I haven't measured the gap, but I did use a ruler to see the flushness between the top and bottom gears, they are fine. When I took the chaincase apart I tied the gears and spacers together in order on a piece of string, so I know they are right. Should I be worried about that much space or putting some loctight on the bolt be good enough?
Thanks in advance
Mike
Thanks in advance
Mike
