Red_RobbinHood
- Jul 13, 2005
I am in the process of changing my track on my '02 viper. I have done all of the necessary leading up to removing the chain case housing from the sled. I have removed all the gears etc.. and have run into a problem trying to remove the chain case housing from the sled. There are 2 "shoes" for the parking braked that are keeping me from being able to easily slide the chain case housing from my sled. My question is it necessary to remove these springs etc. from the parking brake in order to give me the desired clearance to remove the chain case housing from the sled without the parking brake catching on the actual disc brake. I guess i need to know if this is necessary to remove the parking brake and if so an easy way to do this (if at all necessary). If anyone has performed this and can give me some insight i would apreciate it.
Thanks in Advance,
Paul W.
Thanks in Advance,
Paul W.
