aoakwood
I have a 02 viper. The fuel pump froze, I plugged the vent hole in the bottom and it still freezes. It will start and run for a few minutes, then will just die. If I use a hairdryer, aimed at the FP it will thaw and run perfect. I took FP back off, disassembeled, cleaned and reinstalled. Let sit outside overnight and this morning, same result. I had to use the hairdryer to get it going. The dealership says there is no rebuild kit for the pump and wants to charge me $65 for an entire pump. Has anyone had this type of problem? Any suggestions?
you sure you dont have water in the gas cuasing that???
red devil
Wilson
Do you have Isoprople in the tank I am thinking water in the tank also .
I would drain the tank and lines, and discard the gas (properly of course). If all you are feeding the pump is gas it should not freeze.
