bansheedan
What the difference with the exciter 93 sx and the exciter 93.
Im not sure because mine as no more stickers so I want to know what it is.
Where could i go to find a page for the cylinder head torque sequence
thanks alot
thanks alot
Mars
If it has flatslides it's an SX.
Dunno the torque specs though.
bansheedan
Mars said:If it has flatslides it's an SX.
what do you mean by flatslides ?
800
an sx has flats, different cyls, it wider, has adjustable struts, wider bars, if you're not sure the model designation is 8AY, look at the side of the cyls, or the tunnel........... head bolts are 18lbs and the nuts are 24lbs.....start at the middle and work your way out, because of the 2 diferent specs go over it twice, if you're using after market gaskets, go over it twice after its been run, aftermarket gaskets weren't a good idea on that motor.
800 said:an sx has flats
Both are refering to the Carbs. They have Flat slides instead of round. Easy to see if you look down the carb.
bansheedan
800 said:an sx has flats, different cyls, it wider, has adjustable struts, wider bars, if you're not sure the model designation is 8AY, look at the side of the cyls, or the tunnel........... head bolts are 18lbs and the nuts are 24lbs.....start at the middle and work your way out, because of the 2 diferent specs go over it twice, if you're using after market gaskets, go over it twice after its been run, aftermarket gaskets weren't a good idea on that motor.
ok I look at the side of the cyls and the tunnel and it said 8AY so I got a SX
Is it faster at least or better
Does it even make a difference when you order parts
..SNAKEBIT..
I had a SX and I would say it is BETTER
800
it makes a diffence on all the topend parts of the engine, DO NOT put aftermarket pistons in it, the pins are probably in the wrong place. The cyls have different port timing as well as no bridge in the intake, Bottom end is all the same, carbs are unique to that engine, it runs at 7800 rather than 7500, the pipe and the Y pipe are unique also.
Find a set of PSI low rpm twins for it and tune it for 8000 and it wakes it up big time.
