power valve help
rtjim
Moreau Ny
Guys,
I just got done clening the valves and the last one was stuck, when I was pulling on it I heard the servo motor move. My question is will it reset on its own and if I do the adjustment procedure, how much do I lossen the 2 screws on the power valve to check the gap?
Thanks,
Jim
I have not cleaned the power valves yet. Do I un bolt one clean put back same way and on to the next? Do I have to set anything before or after? And clean with scotch brite and break cleaner each. thanks.
one at a time. viper7mi, where are you? i live north of lansing, and i would be glad to show you how to. if you bring the sled to me i'll teach you how to pull, clean and set the valves free of charge. all i ask is, after the teaching you use the knowledge to teach another. this is how and why TY is the best sledding board on the web. let me know, it really is no trouble at all, and i am on vacation and staying at home all week. ski
Quick note, I have all three PV pulled and going to reassemble today, which way does the beveled edge point. Down correct? Thanks
That was quite the offer, wish you lived in Maine!!
:yam:
skidooboy I live near the novi expo center, not to sure how far that is from you? I would have to a map search. PM with the address and sure to pass on the knowledge.
viper7mi
go to the tech section of this site.it explains how to clean the valves.there is alot of good info there.better yet buy a manual knowledge is king
