ReaperSRX
Because i don't have an alignment tool i had the shop check and set my clutches up, now i have pulled both clutches to install new set up(springs, helix, weights), i have also purchased the MaxxPerformace belt deflection adjuster and it states to make sure you have clutches aligned. My question is do i have to get the clutches re-aligned because i pulled them both off?
yamyrider
you will have to get the offset aligned. Your center to center should not change and you can check the belt hight on the secondary yourself since you have done work on the secondary clutch.
Srxspec
Your #1 performance shop!
I have the correct tool to check the clutch offset for $18 shipped in the US, would be a few more $$$ shipped to Canada. I can take pictures if you're interested.
Junior
damned good tool to have man
No other easy way to check center to center.That should be checked every year as well as off set.
ecopter
Srxspec,
Sent you a PM.
Thanks,
Jon
Sent you a PM.
Thanks,
Jon
ReaperSRX
Could you post a pic and how much shipped to Ontario Canada, P0J 1P0. That means i have to take the carbs off again, darn just had them off to clean.........James
Srxspec
id loan you mine reaper but it not in yet. that and yamiman has dibs after im done with it.
yamyrider
Hey Maim,
If you are handing it out put me on the list.
i meant you dude lol
