hotdoggy
HI Everyone
I have 1999 Srx 700 and 2001 Srx 700. This is about the 2001, the 99 has no problem starting. In the 2001 the heads have been shaved, cluched, carbo-tech reeds, geared and 1 1/4 rip-saw track. It takes about 10-20 pulls to start. It doesn't matter if it is cold or warm. When it has been sitting for a week it takes about 20-30 pulls. I get mad and pull the plugs and dump gas in the jugs. I heard that there is a small pin hole in the bottom of the fuel pump that should be plugged. Has anyone heard of this or not. I am also thinking about putting in a fuel shut off or a primer. Any help would be awsome. Thanks
Might ck. pulse hose from engine to fuel pump
blueblooded
I always had to hold the throttle open a bit and pull it over to get my srx started once it was warm.
2001SRX=Fast
I would put a primer on. I have one and it saves my arms.... I think it is because the gas backs up and then your carbs dry out. so install a primer.
hotdoggy
Thanks for your help. No one knows about the small pin hole in the fuel pump.
Would this be a headlight relay problem? Sounds crazy, but there was a relay kit that would help. PM mrviper700 I think he knows.
Blue, Mine does the same thing, it's normal. Drives me nut though. I'm getting used to it.
hotdoggy
wanasrx
my 99 is good. i have taken off the light plug-in and that does nothing.
Here's a link I found.
http://www.totallyamaha.net/forums/showthread.php?t=8306&highlight=headlight+relay
hotdoggy
wanasrx
thanks
thanks
Here's another for the install. Hope it works for ya.
http://www.totallyamaha.net/forums/showthread.php?t=9660&highlight=headlight+relay
