gearing for 2000 sx700r
i was looking for 20 top gear and 40 bottom, but not a hundred percent on whats in it stock for reverse maybe you know thanks dave
what kind of parts , or what gears that go on reaverse, i am looking for 20/40 gears but my machine has reverse and the dealer said they dont make option gears for my sled.any good info would be nice thanks
You can get a 20 for the top but the only gear for the bottom is a 39.if you wanted the ratio that the 20/40 would be .You can run a 19 top with your 39 bottom giving you a 2.05 ratio.Which the 20/40 would be a 2.0 ratio.thats the closest you can get.
so richierich do you have a 19 top gear for 2000 sx700r that has reverse on it or know were i can get one thanks dave
also richierich what is the stock gear on top anyway i can not seem to find out from anywhere on a reverse model like mine thanks dave
The gear is $20.you should have a 22 top ( 700 deluxe model)now.The ventures had a 20 stock.both came with a 39 bottom.Your sled sx-r 700 didnt come wth reverse someone added it.if your in canada you would be cheaper getting it up there.heres the part#
89J-17682-91-00 SPROCKET, 19T
