2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Here is a tip for some of you guys who have trouble cleaning your powervalves. I had some of this stuff laying around so instead of messing with solvents, I tried some aircraft paint remover on the PV's. It just ate through the carbon. All you have to do is spray it on, let it soak for 10 seconds and start scrubing with a scotch pad and within seconds the face is clean on the powervalve. IT is the easiest thing I have tried and it eats the carbon much more efficiently then other solvents. Just a tip to speed up your cleaning process.
yamvip
Thanks for the tip,I'll have too try that the next time i need to clean them.
03viperguy
doesnt take of the coating as well?? sounds like a neat trick though
ReaperSRX
Working at a GM dealer i tried a product called "Kleens" on the advise of a mechanic, let the PV soak for a few hours and turns carbon to mush, just wipes off ..........James
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
The PV has a hard coating on it so the aircraft remover does not penetrate through that. I am telling you guys, this is the way to go for cleaning the PV. Spray it on, wait 10 seconds and scrub for 5 seconds and it is all gone. Worked perfectly.
Does the aircraft remover come in a spray bottle? All I ever used was the aircraft remover in a gallon can, kinda thick and orangish.
blueblooded
2ooosrx said:Here is a tip for some of you guys who have trouble cleaning your powervalves. I had some of this stuff laying around so instead of messing with solvents, I tried some aircraft paint remover on the PV's. It just ate through the carbon. All you have to do is spray it on, let it soak for 10 seconds and start scrubing with a scotch pad and within seconds the face is clean on the powervalve. IT is the easiest thing I have tried and it eats the carbon much more efficiently then other solvents. Just a tip to speed up your cleaning process.
Where can i buy some??
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
I bought mine at advanced auto parts to strip some more things on my sled to be polished so I gave it a try on the Power vavles and it worked extremely well on that too. Here is a link to the exact product I used and it come in a spray can.
http://www.partsamerica.com/ProductDetail.aspx?categorycode=3272&mfrcode=MHY&mfrpartnumber=2811
that stuff is some strong stuff it will eat through anything but metal.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
pro116 said:that stuff is some strong stuff it will eat through anything but metal.
lol, I can vouch for that, when I was cleaning my PV's I was using a big scotch pad so I folded it and all of a sudden it unfolded on me and shot some of that stuff in my eye. Man did that sting. I flushed my eye under water for 10 minutes and was good to go. To bad it can't get anodizing
doc04viper-s
Someone told me that they have used easy off oven cleaner or BBQ grill cleaner and it worked pretty good. I haven't tried it but thought it maight worth mentioning.
ecopter
Do not use oven cleaner. You'll really be sorry as that stuff eats right into the metal on those powervalves. It will pit them.
Jon
Jon
