Track Tension 04Viper
04VIPERS
Mass
Can someone tell me the steps to take the slack out of my track. Do i have to losen the back wheels first before turning the track tenstion bolts?
the adjuster bolts are inside the track windows, behind the outside idler wheels in the rear. You will need a 14mm deep well socket to adjust them. Don't forget to loosen the axle nut to adjust, and make SURE to retighten it and reinstall the cotter pin. Seen several people lose their rear axle now, not pretty.
Yeah,just loosen the axel nut (no need to remove cotter pin) and adjust evenly through the track holes,and then retighten.
