Can someone tell me the steps to take the slack out of my track. Do i have to losen the back wheels first before turning the track tenstion bolts?
n2oiroc
loosen the rear axle bolt (no need to remove cotter pin) and adjust from there!
yamaholic22
the adjuster bolts are inside the track windows, behind the outside idler wheels in the rear. You will need a 14mm deep well socket to adjust them. Don't forget to loosen the axle nut to adjust, and make SURE to retighten it and reinstall the cotter pin. Seen several people lose their rear axle now, not pretty.
yamvip
Yeah,just loosen the axel nut (no need to remove cotter pin) and adjust evenly through the track holes,and then retighten.
