helix
sledfreak700
White Lake, MI
can some one tell me what angle helix this is bender part#9970.and would it be better than a 51/43? I have bender tripple pipes,reed spacers.Thankx :yam:
9760 - 49/45
9770 - 49/37
9770s - 51/39
9770tp - 51/43
9860 - 51/45
9870 - 53/43
9970 - 43/35
2070 - 47/43
Wow, not only did you know the angle but what sled it's for. How do some guys just know all this stuff? Thank you very much for that info. How do you think that will work on a 2001 sxr with head gasket mod, reed stopper notch, and bored silencer, geared down 1 tooth on top? I got the whole 9960tp kit.
Meat that should work try it with the stock weights and see where your rpm's are you might have to add a little ( bigger rivet) weight to lower rpm's! Wrap secondary at70 deg. Let me know how this works.
