Help me guys ! I added the longer struts from a 1994 600 to my 540 and was thinking of dropping the rear of rear suspension mount 2 1/2" to offset the front by using Exciter brackets that place the rear or rear holes under the running board instead of a hole through the tunnel. Would I have to move the mount hole forward and drop the carrier shaft ? Could I leave the front mounting hole in the stock position and what effect would this have on hyfax wear, transfer ect... ? Thanks for any help ! Chuck PS. I got one reply on Snowest saying this would screw up the rear suspension geometry.....I don't see how basically raising the rear of the tunnel can change the suspension ? I can see it changing the handling ?
