00' sxr 700 dies, need help
wanasrx
Ghent, NY
When hitting a large mogal/bump she looses throttle. It stays running as though on one cylinder. Will not take any throttle. Let sit running for a few seconds and she comes back running just fine. Can anyone help? Could it be a common problem with an easy fix?(I can always hope). Sled is completely stock, carbs cleaned. Also, always have to hold throttle open a bit to start it(warm).Normal?
JMO
Some of those erra sleds had a wire chaffing problem, could be the culprit. Maxdlx
:twisted: connections to the t.o.r.s. were not connected good enough when I cleaned carbs. just took them apart and put them back in and everything was ok! :twisted: :twisted: hope you have the same luck.
