When hitting a large mogal/bump she looses throttle. It stays running as though on one cylinder. Will not take any throttle. Let sit running for a few seconds and she comes back running just fine. Can anyone help? Could it be a common problem with an easy fix?(I can always hope). Sled is completely stock, carbs cleaned. Also, always have to hold throttle open a bit to start it(warm).Normal?
Have you tried bypassing your TORS to see if it goes away. easy test.
Good one, I should have tried that. Going to do that next time out.
YaMon
Gotta Be T.O.R.S, had the same thing happen to me crossing streets, not too much fun. YaMon
JMO
Some of those erra sleds had a wire chaffing problem, could be the culprit. Maxdlx
