radius rods
no and yes
they are longer by about 3/4in
the lower is the correct configuration if you use the inner rod end from the srx.
the upper will not work unless you do alot of grinding on the inner end it is about 1/4 to wide, if you reverse it to the outside it still is a little too wide, is angled wrong, and the hole is too big.
if you are making you sled wider they either buy sxr rods, or have a welding shop cut the slugs off yours and sleave a pipe over them to make them the length you want.
