SXViper 1+2=3 cylinders
- Feb 27, 2005
doing a pre-season check and found my oil pump out of adjustment. it is at 22mm.... manual says for 20.5mm. so am i too lean or too rich? if it's rich i might turn it down to 21mm and call it fine.
- Feb 27, 2005
thanks. guess i oughtta rein it in a little?
blueblooded
How and where do you measure??
98srx6
blueblooded said:How and where do you measure??
The cable free length at the flipper.
- Feb 27, 2005
98srx6 said:The cable free length at the flipper.
huh? no, there is a black cable just above the carbs with a rubber covering over about 2" of it. pull that rubber back, and pull the metal nuts apart, and measure the gap between them.
blueblooded
SXViper 1+2=3 cylinders said:huh? no, there is a black cable just above the carbs with a rubber covering over about 2" of it. pull that rubber back, and pull the metal nuts apart, and measure the gap between them.
Ok thanks,that makes sense.Thanks.
