04dgmsilv
- Nov 21, 2005
I've got a basically stock 97 700sx (just a bender silencer) that has had the Bender CK9770S clutch kit in it since 99 (only 4500 mi. though). I clean the clutches every year, last year I attempted to replace the springs with help from Bender, but got all the wrong parts. Leads to my question, What would the be recommended springs, weights, rivets wise while keeping the bender helix?
The helix is p/n 9770s (51/39, from what I have found on here). I am not planning on opening the motor up (i.e. no gasket changes), just refurbishing the clutches.
Turk
TY TECH ADVISER
- May 2, 2003
Stock springs but run a 4.5 gram inner & outer rivets. If that is the right helix rpm,s should be about perfect if that is a 51/39 helix. Get rid of the can & put the stock one back on.
