Clutching questions for Turk's setup
SX700R RIDER
I have a 2000 SXR 700 on TUrk's set up page, it says I need 14.5 mm rollers. The stock Yamaha spec sheet on this site says I have 14.5 is this true? I have 8 DF weights that setup was for a 1997-1999 which has 8 CH weights. Which weights are better for an SXR? The 8CH or 8DF? Thanks!
That is on a piped sx-r. You need a 51/43 helix & change inner rivet in the stock weights from a 3.6 gram to a 4.5 gram rivet for a stock sled.You don,t need to change rollers.
