dieseltodd
- Oct 29, 2005
I got an 2000 MM Max , everything is stock , Im going to add the head mod to it also the can mod and I was wornding if you would have some clutching advise, mostly off trail riding but some county road riding also. The guy that giong to ride it is 175# with all gear, Would a smaller top gear be good for some more pull also. THANKS Todd Flatlander in Michigan
Gearing is fine. Clutch the same as a flatland sled...51/43 helix, 4.5 gram inner & a 3.1 gram outer with 70 degree wrap on the secondary. I used the 8cr weights in my mm & when dialed in they worked well on the flats.
dieseltodd
- Oct 29, 2005
Turk
Thanks Turk for the speedy replyTurk said:Gearing is fine. Clutch the same as a flatland sled...51/43 helix, 4.5 gram inner & a 3.1 gram outer with 70 degree wrap on the secondary. I used the 8cr weights in my mm & when dialed in they worked well on the flats.
