How do you get your clutches to jive.
2001SRX=Fast
Manitoba,Canada
Well my clutches are not working together. They are fighting each other and i know that because i tryed them on 2 srxs and they were doing the same thing...
The primary gets soo hot that you cant even touch it for a while.
This is what i am running
Primary:
8bn-20 4.5inner 4.5 outter
Orange Hauck
Stock rollers
Secondary
red spring wrapped at 80
How is alignment & centre to centre? Might wanna try a w-w-w primary spring too.
What are stock rollers, could smaller rollers help. Just a stab Did you use different belts for different sleds, or same belt on all 3. :yrules: Maxdlx
Riding in soft slushy snow with a lot of upshift & backshift will heat em up. Might wanna try tightening the secondary in sloppy snow.
If your clutches are hot you're slipping the belt, I would agree with Turk, try throwing a Yamaha green in the secondary you'll get more pinch
