yammy_freak03
- Aug 25, 2003
- Winnipeg,Manitoba
- www.winnipegsportandleisure.com
ok well i havent taken the sled out yet since i changed the helix back but will the stock helix make a big difference on the bottom end compared to the 53/43?
Thanks mrviper, that's what I figured.
Rambunctious
Results Of 51/43 Helix
so I got out this weekend for the first time
51/43 Helix with stock red spring at stock windup ( 90 actually, I mentioned 60 earlier on)
and it climbs to 8600-8700
I can be going 50mph and hammer it, it goes to 8600-8700
i didn't have space to open her up to terminal velocity, but i got to 105mph on the speedo at ........8700
so.....
should I back off 10 degrees on the spring winup??
and what holes is that. the 9 instead of the 6 on the helix right???
one other thing, i sitll have the stock track with 192 studs. I will be replacing with a 1" with "tall" 144 studs.
will this track improve traction enough to "lug the engine" so I should wait on messign with the spring, or at high speed, you get what you get with the rpm and I should adjust down.
thanks
Ramb
so.....
thanks
Ramb
back her off a little
yes, back the sring tension off to 70-80 degrees, thats 6 on the helix and either 2 in the clutch, for 80, or 1 in the clutch for 70.
Remember me saying "run it as loose as you can while still controlling the shift".
ya gotta go test and keep notes
Rambunctious
Thanks!
will try and then report back
Ramb
Ramb
