haha hey guys !. Nice to see such an enthusiasme!
Gees I`m sorry to say it but it seems NOT to be a plug related issue we got here.
The last time I changed the plugs on the sled I put in abrand new BR9ES (had one lying around from my old V-Max) and a used BR9ES that looked somewhat wet/fouled.
Today I removed the old BR9ES and put in a brand new BR9EG from my dirtbike (just to see if it would function better, will not run the sled on that plug in the long turn). I checked the sparks and there was a nice clear/sharp spark at both plugs. I wiped off the BR9ES with a paper towel because it looked a little wet. I put both plugs in and cranked her up. NO DIFFERENCE.
Is it possible that the cylinders/heads/crankhouse can be so covered with oil that the engine just can`t manage to get it clean?. (probably not, hehe, but I remember on my Rotax 583 engine, if it was really soked with fuel/gas I used to take out the plugs and let it sit for a day just to air it out, funny thing, I welded the engine into the frame and I angeled it wrong so that the fuel kept flowing from the carbs to the crankhouse, when I pulled the starter rope I once pulled it off due to the heavy resistance the fuel made in the crankhouse, haha).
I removed the plugs from the V-Max after I tested it, the left side plug was totally cold. The right one was a little hot, could easily hold it in my hand. Sled had idled for about a minute. Wierd actually because it seemed like it idled somewhat on both cylinders. The next time I try it I will put my hands one the exhaust manifoils, I will not be surprised to find the left side totally cold. However, if I ride the sled with lots of rpm I guess it will run on both so basically I haven`t found out anything more today.. .
When looking at the carbs (see the pictures I posted of the carbs) from the air filters view, you see a tiny jet, I did not take those jets out. If one of these jets are plugged could they have something to to with it?. I tried to remove them but my screw driver tended to slip on them so I didn`t want to ruin them. (I did blew through them though).
Gees the last couple of days I`ve fiddled with so many things but if I just put the V-Max on top of my "priorita-ry-ze-se`?" list, then I`m sure I will be wiser.
